The washer's door is locked and water is in there too. It happened during the working. how can I open the front door? My wahing machine is Maytag Neptune.
If you have a Maytag Neptune MAH3000, MAH4000, MAH5500A or a 2000 stacker then your wax motor might be the issue. See www.neptunehelp.com for info on the faulty door latch wax motor and how to fix it.
If unplugging machine does not allow the door to open then remove the 4 philips screws on the soap dispenser bezel ( under lid) and remove it. There should be a colored plastic cord in there you can pull on to unlock the door, It is an emergency pull cord.
The door should open when the mains is turned off. it has an electormechanical swich. turn off the mains and leave for 5 mins then try. hope this works
