When we turn on the tv it turns on but then three seconds later it turns right back off. We heard about a reset button but cannot find it.
SOURCE: My Mitsubishi turns off automatically...
I had the same problem with an RCA, check your sleep mode settings on it, it may have defaulted to 1 min, so it cuts off when it cuts on
SOURCE: Power turns off automatically
Same w/ mine. Repairman said they turn off auto to protect the set no matter what is wrong. Take it to be fixed. Mine was right at $100. Works great again.
SOURCE: mitsubishi diamond series tv
I have a 2003 mitsubishi WS-55711. While watching TV the other day it just shut off. When I pressed the power button, the green light turned on for approximately 3 secs, then shuts off. I've attempted to simply unplug it for a period of time in hopes that it would possibly reset. However, the same thing happens. Is this a problem I can fix on my own or does a professional need to fix it? If I do have a pro fix it, what is the likelyhood that it will happen again? Should I just invest in a new TV? Thanks
SOURCE: tv turns on for about three seconds and then turns
here's a simple test, tap the unit several times and see what happens.but, whatever happens, call a tech,it has already faulty components inside.
