Will not charge the port wont stay its loose
You will need to take the laptop to a qualified service shop to have it repaired. Usually, the charging port is held onto the mainboard by small solder connections. If the charging port is loose, then these solders have likely been broken. You can try to fix it yourself, but you wil have to disassemble the laptop and re-solder the charging port back in place. If you are not comfortable doing this yourself, then you should take it to a service shop for repair.
Hope this helps!
Joe
SOURCE: Can I repair a loose power port on my ibook g4?
its posible but first make sure its not under warentee if so send it to apple thay will fix it if not then the only way to fix it is to order the charging port and resauter it to the board
