E:|\SETUP.INF The version of this file is not compatible with this version of Windows your running. Check your computer's system information to see whether you need a X86 (32 bit) or x64 (64 bit) version of this program, and the contact the software publisher
SOURCE: i am not able to run turbo c++ on my windows 7.it
Depending on your version of Win7 and your computer specs, you could try to run the software in the XP mode (Pro or Ultimate). This is a virtual machine and needs dedicated memory and does not directly share files or peripherals with the real machine. It has worked well on our machines for several older programs (Win2K and XP versions) - these were 32 bit programs and ran on a 64 bit Win7 Pro machine.
Running the program in the compatibility mode might work as well (right click, choose properties and then the compatibility tab).
I hope this helps.
