I'm trying to find a good site to download an instructional manual for a Sanhaun 6050 r/c helicopter. It is a 6 channel and the controller needs to be programed. Can you help? Thanks!
But my thought is that being left on the shelf with a flat battery set has ruined the batteries and you need new ones. The manual says it takes 6 x AA rechargeable batteries. It also says the switch must be in the Off position when you charge. Page 6 and 7.
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
