Nikon Coolpix S3000 Digital Camera Logo
R
Randy Marler Posted on Dec 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Nikkon Coolpix s3300 displays everything in unfocused shades of purple and anything that is emitting or reflecting light glares like it is being viewed through night vision goggles. Is there a fix
The camera is not very old and hasn't been used that much. It worked fine in the morning but when I took it out later that day it was having these issues.
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Dec 25, 2014
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83783
Points
625
If it works in the morning (when it is presumably cold) and not in the afternoon when it is hot, it is possibly a temperature sensitivity issue in the electronics. I would contact Nikon Support ASAP because your warranty is about to expire. There number is 1-800-645-6687 and the are open 9AM to 8PM EST, Monday to Friday.
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on Oct 16, 2007
SOURCE: Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
Anonymous
  • Posted on Mar 02, 2009
SOURCE: black screen coolpix S1
September 9, 2007 3:56 PM 39 thumbs-up.png 1 thumbs-down.png Hi, Please forget the above findings of mine. I just realized that it is a feature of the camera when it fails to focus on an subject for consecutive 5 times, the lens will intialize itself and out put on screen a message: INITIALIZING LENS CANNOT FOCUS.
I just got the camera defective like conditions of yours. Tried to find help on the web and came across this site while testing on the black screen camera for not more than 45 minutes.
I have the instruction manual, but never flipped a page on it yet. So how the heck do I know about that 5 times things on focus as mentioned above. BECAUSE I got the stupid camera working right now with the real time image on the screen.
If you want to follow my way to try fixing it yourself, keep reading and do it at your own risk. You paid several hundread dollars for the camera and I just paid $20 for it. Therefore, I tried everything I can to make it work, even if I had to open the camera body to play with the inside. Fortunately, it was not neccessary to take it apart.
Once again, AT YOUR OWN RISK to follow my way to get back your real time image screen.
Read the following steps once and make sure you understand before action.
(1) Load your camera with a freashly recharged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
I got mine fixed by performing the above steps just once, but I started at a medium impact force. Before this fix, I tried to whack it on both sides, the top and the bottom to my knee cap.
Why I chose knee cap and elbow? They hurt if you strike too hard. The target is to apply enough impact force to shake but not break the parts inside the camera.
Good Luck!!
Anonymous
  • 744 Answers
  • Posted on Jun 28, 2009
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Is there a way to reduce glare on a pair of plastic prescription glasses
I would like to suggest you,to use glasses that are made up of AR coating to virtually eliminate reflections from the front and back surfaces of your eyeglass lenses. Few sunglasses stores like EL sunglasses ( Products Archive EL Sunglasses ) have made up with cheap polarised sunglasses which enables to reduce glare while reflection emits.
3helpful
3answers
Reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
2helpful
How do I delete videos from Coolpix s3300
Hey there,
All you need to do is reformat the memory card. It will erase everything on the card. You will find the option in the menu
1helpful
Magellan Maestro 4250 GPS, the display seems to wash out on sunny days so that it is unreadable. That's without direct sunlight on the unit. Can anything be done or adjusted?
The Magellan 4250 LCD display brightness settings does not do much. I can understand how annoying it is to have the sun's glare on the display making it unreadable. You can improvise a simple sun shade like i did, cut and fit a card board strip on top of your GPS unit to block out the sun glare. It's just simple and cheap solution.
When I am taking pictures outdoors there is so much glare that I can not see the picture I am taking.
Have you tried a glare shield, or LCD hood?
A glare shield reduced reflections, whilst an LCD hood folds out and provides "miniature shade" to assist in viewing.
Here's a 2.5" example (for pentax). Generic ones (such as Delkin) are cheaper.
http://cgi.ebay.co.uk/LCD-Hood-Protector-for-Pentax-K10D-K110D-K100D-Super_W0QQitemZ390160188648QQcmdZViewItemQQptZUK_Photography_DigitalCamAccess_RL?hash=item5ad75c04e8
For more types, search for "LCD Hood" on eBay, Cameras
Glare with flash
Go into youe setup menu and set everything to automatic. Set your white balance to the center, or '0'.
1helpful
2answers
Glare on lcd screen
it's pretty normal.. try wearing a brimmed hat to create shade, turning the brightness up on the screen, the lcd's tend to get washed out in the bright sun.
2answers
The focus on the NIKON COOLPIX P80
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
May 12, 2008 • Cameras
Screen glare
Silly question but are you facing into the sun at all, they don't always like seeing any of the sun!
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
