Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman dlt2000 mower and the blades r ingaging about half of normal speed with out even pulling the knob out
  • Anonymous May 18, 2009
    the deck belt looks ok but is there more belts up inside
    Problem Solver:
  • 4 Answers
Could be a belt problem
Posted on May 18, 2009
6ya staff
SOURCE:
Craftsman lt 2000 42
Hi, first check the spring that pulls on the idler pulley for lost tension then run the blades for a 10 to 15 minutes at half to full throttle. This is necessary to bed the new belt into the old pulleys. Regards Phil.
Sep 05, 2012 | Garden
Have a craftsman mower just purchased riding how do I get the blades to work so can cut yard
if it is a newer model while on the seat there should be a yellow or red knob you pull out to turn on the blades they will not work in reverse(a safety thing)
Jun 28, 2012 | Craftsman Garden
Blades don't ingage
look and see if the belt came off the pulleys, it could be at the front pulley or at the rear pulleys. lower the deck all the way down and look.
Jun 12, 2012 | Craftsman Garden
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades wont ingage on my craftsman lawn tractor #917.274811?
After hitting a tree root, blades will not cut when I press to engage
Aug 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
CRAFTSMAN 26 HP 48'' DLT2000 MOWER ELECTIC PTO CLUTCH SEIZED UNPLUGGED BUT BLADES CONTINUE TO TURN. CAN IT BE REPAIR OR MUST IT BE REPLACED?
I would say replaced to ensure correct opperation.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
When I pull the blade lever the blades do not turn. Found that the trottle wire to pto is broken. Need instructions and a diagram on how to fix it. Thanks
just wire it back together, you don't have to worry about crossing the wires up. because it's just a hot and ground for a coil to magnitize to ingage the pto clutch.
Jun 21, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
260 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
