I just purchased the Trio Stealth Pro 7" tablet for my son for Christmas, it will not charge and shows a battery and with triangle in the center. What does this mean?
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
This may not be the problem, but worth checking. I ran into this the other day with my Trio Stealth pro tablet. I had left it on while unplugged and it drained the battery completely in sleep mode. It would only show the startup icon and shut right off. After a complete charge it is back to normal operation. You might try making sure the charge is full, maybe the battery has gone bad and that would also affect operation. Also try starting it up without the SD card in. If it doesn't mount properly or a file is corrupt, it may act strangely. I believe it scans the SD card first and may be trying to startup on it. Other than the above mentioned, it could still be hardware related with Ram or CPU problems. Good luck in finding the problem, tablets can be fun but frustrating sometimes.
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
