Televison & Video Logo
richard pyle Posted on Dec 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer pdp-5070pu HDMI port 5 has a megenta hue to it. All other HDMI ports and component ports are fine. What board might need to be replaced?
If I try to use the HDMI port number 5 on the TV the image has a strong magenta cast to it. All other HDMI ports work fine as do the component input ports as well as composite video. What board part numbers would have failed?
Lawrence Oravetz
Level 3:
  • Televison & ... Master 10,558 Answers
  • Posted on Jan 06, 2014
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2699395
Points
29284
The main board that has the HDMI ports on it. The numbers can be taken from the board itself. Once the board is replaced, you'll have to go thru all the setup menu's because the memory is on that board too.
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Jun 08, 2012
SOURCE: Can anyone tell me the part number of the HDMI board in a Pioneer PDP-6010FD?
Check this link for details.
Vizio M470NV from 2005. All HDMI ports out. Replaced mainboard (twice) still HDMI. Any other component I should replace? Daughter board? All other ports work fine (VGA, Composite...)
I am certainly no expert about such things but a friend had a similar problem until he discovered he needed to get into the menus and switch on the port he needed to use.
Hdmi input not working
Do you have a second signal from your cable box going into the TV by a different port?
You can only use one or the other, not both.
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
PDP 435HDG HDMI selection
Do a factory reset to this set and proceed. Refer its user manual for details.
2answers
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
2helpful
5answers
Where can I sell a pioneer pdp 5070pu plasma tv for parts?
HI, the best way to do this is to disassemble the set and post all the individual internal parts like the power board and main PCB logic and v boards, on line on a e-bay type of sale forum. this way, you can make more money. if you post the entire plasma screen with the crack as is, you will not get many hits. is will be assumed that it is damage goods.
Breaking this set down and, posting the internal circuitry piece by piece will make you more money in this case. The power supply board will sale for at least 289.00. and the main logic(PCB) will sale for 300 to 350. i would go this route to maximizes your gain.
2answers
Cables
Greetings 4mother,
It would really depend on what type of hook up you are using. Most of the time a plasma television would be hooked up with either and HDMI or component cables. Your local store should be able to make a solid recommendation based on the items hooked up to your television such as cable or satellite box, dvd player, etc.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
