The only way to fix this problem is to get it repaired.Please call canon on the main support no.1 800 828-4040 and they will tell you the nearest service center located in your area
The repair of this will require the inspection of the deck by an experienced Technician of whom I would suggest be Russ Bachmann at New Jersey Factory Service. I would look at it myself but I am in the Chicago area. Shipping most often pushes reel tables in and the brake band usually is not damaged at all. There could be the problem with sticky tape- if you have 406 or 456 and the tape path is accumulating a brown residue that is the problem not the machine. Tascam Repair New Jersey Factory Service Mahwah NJ Home
The hum is a tube that has gone weak or a volume switch that may be going out! Try a TV repair shop in your area, and call first so they can tell you if they are familiar with the old equipment!
The cost of the rocker arm actuator is not listed online, for the part or the repair, but it appears to be costly. Try contacting your local Honda Dealer which is Honda of Toms River 346 Route 37 East, Toms River, NJ 08753 (732) 349-7474. if you need an auto tool to solve your problem that happened in your cars you can click here: great tools
the part is probably under warranty as you have stated but the labor is most likely not and that would be why the installer is not responding.. Not right but thats what some choose to do.. Report them if you feel called to do so.. and then contact these folks.. Cranbury Comfort Systems
The inverter powering the display or its power supply have most definitely gone bad.
Manufacturers are generally very good about fixing their own stuff for cheap or free. You may just have to pay to ship it.
if they agree to fix it, afterward ask if there is a local service center where you could drop it of for warranty repair.
Contact LG service directly at
1000 Sylvan Avenue Englewood Cliffs, NJ 07632 Toll Free: (800) 243-0000
Sounds like your shutter blades may be out of position. That can be repaired. Canon is located in Jamesburg, NJ or you may contact an Authorized Service Center. I don't know where you are, but there is one in Florida 305-653-7355.
good luck
right here on fixya.com...go to the service directory and shop around for your area,,,your spin surport basket most likely leak through the back tub seal..
