Hi Dakhara Shaw, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? is it the stock app you're using or is it one from the Play Store?Hi Dakhara Shaw, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? is it the stock app you're using or is it one from the Play Store?
My mother got it for me from clearance.co but when i try to open my camera it says super hd has stopped working what does that mean?My mother got it for me from clearance.co but when i try to open my camera it says super hd has stopped working what does that mean?
You can't post conmments that contain an email address.
I would try and contact the programmers that put these out and see what is going on. It may be that the game is not made to work with your specific unit.
It is different depending on which zeepad you have. From powered off, which yours sounds like it is:
1. Hold down both volumes and power at the same time. You should get an android on its back opened up.
2. Press both volumes at same time to open up a small blue text menu.
3. Then use Vol - and Vol + to navigate the Recovery mode.
4. Select "Factory Data Reset"
5. press power
6. choose "yes" from the menu
7. then press power again.
If this does not work try holding down the volume and power at the same time.
could be corrupted data or bad app,going to settings and reset to factory default that should fix corrupted data, if it still persists check for firmware updates in the settings, then check for app updates. if it still exists after that return back to factory for warranty repair
