I need to order another filter assembly for my Lg washing machine model numebr wm2277hb and cant seeem to find a part number for it. I ripped the rubber gasket while trying to remove it and clean it.
It would cost about $500 to $700 to replace the bearing. It is a big job because the drum has to be replaced because the bearing may have damaged the drum shaft so it's recommended to replace the drum assembly along with the bearing assembly. If you decide to do it yourself, you will need:
The rear tub assembly which includes the bearings
The tub seal
Drum assembly
Good luck.
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
THATS A RIP! THE PUMPS ARE ABOUT 65$ THERE IS A CLEAN OUT ON SOME MODELS BEHIND A DOOR IN THE FRONT BOTTOM OF YOUR WASHER. INSTRUCTIONS SHOULD BE IN YOUR MANUAL
It is a long drain error and occurs when the washer is not fully drained after 10
minutes of draining. Remove the cabinet cover and check the following:
Drain Pump Connector The connector may be disconnected or disassembled. Reassemble or repair if necessary.
Drain pump coil Check
pump coil resistance between the terminals using an ohmmeter.
Resistance should be between 10-20 ohms. If the resistance is too high
or too low, replace the drain pump.
Voltage Check the voltage between the connector
in step 1 during spin. The voltage should be 120Vac, else replace the
main board assembly
Main board replacement:
Disconnect the power connector and sensor switch assembly.
Remove the main board protective cover.
Disconnect the connectors.
Remove the screw on the back of the main board.
Slide the main board to the right then pull it up.
