I installed new timer and water inlet valve and washer still won"t fill with water. everything else works fine.
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hi
Daniel
Hi
Daniel
Take a look at your fill hoses (from the wall to the washer)... are they the stainless steel "flood safe" type?
SG
When fill switch is pressed, the light just blinks and no water comes into the basket.
no water. Control board?
samsung washer no water won't fill
Washer is turning on but tank is not filling with water at all.
The washer turns on but won't do anything
