SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
SOURCE: I was trying to wall mount a 32-inch flat screen.
If you get a slightly larger drill threader bit you may be able to rethread the hole to a slightly larger diameter.
SOURCE: I own a Samsung DLP
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
SOURCE: need 4 screws for phillips 42pf9946-12 plasma tv to fit wall bracket
Best way to be sure is call Philips customer service with the model number to get the thread type and length of these--no two sets are the same here---usually most will be available at local hardware stores if Phillips does not sell them(that would be a bit more pricey and take time).
