Question about Sennheiser HDR 120 Consumer Headphones
No sound, only static
The on/ off green light is not lit.  We have checked the connections and the batteries.  We had good sound, but now all we get is static.
  • 5 more comments
  • manoloeg Dec 12, 2007
    green light will not turn on, only static, working fine the day before
  • Anonymous Dec 23, 2007
    Same Here - Worked for a shile and no nothing except static...
  • Jarby Dec 27, 2007
    Same problem. sound works for awhile, although mostly through right earphone. Each time a hint of sound comes from the left side, the green light goes off and all I get is static. I removed batteries, unplugged AC power for a minute to re-set, but the same thing happened again in about 10 minutes.
  • judgep Jan 18, 2008
    I have tried 2 sets of rs 120 and, after only about 5 or 6 hours they start cutting out when in use for 1 to 2 hours. I'm 20 feet from TV and they transmitter.
  • Jon Kenny May 03, 2008
    Have the same problem,green light go's off & get an earfull of static,have unplugged unit from tv,plug it back in & problem is solved for about 10 minutes.Have had product for over a year & had no problems before.
  • sidglor100 Jul 03, 2008
    My headsets are RS120....a few years old...working well...However...the On & Off light goes off (while connected) but the red charging light will remain on. Sometimes. none of the light will go on?????Do I need new rechargeable batteries?? Or what? Sidglor100@netzero.net
  • Deb The Web Dec 05, 2008
    The green on/off light is lit sometimes and sometimes not. Have tried to tune to all of the three channels and only get static. I followed all the trouble shooting suggestions.
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Posted on Feb 20, 2009
My mother's headphones have worked great until recently. after a visit from some of her grandchildren, they no longer work on the television in her family room where she always used them. i took them to the living room and was able to get them working on that tv, but still no luck on the other tv. any suggestions?
Posted on Aug 13, 2010
    New Friend:
I had the same problem. I guess someone had bumped the channel switch. As soon as I changed the channel on the base of the transmitter, the on/off light worked and the headphones worked fine.
Posted on Jan 03, 2010
I had no green light, just static etc.
If you have any other wireless equipment nearby it could be worth moving the headphone base station. In my case wireless router and dect phone were close. I moved the base and immediately the headphones started working again.
Posted on Feb 28, 2008
I have changed batteries to higher spec and seems to have solved problem ,something to do with amps ...
Posted on Jan 26, 2008
6ya staff
SOURCE:
Bosch W135 water heater Not igniting, no clicking sound. Replaced batteries and still not lighting
i think you need to check the battery holder is good
and your getting the right supply to the internal ignitor board
if it uses 2 batteries then check there connections are metal
and not gone green or other issue with oxides
and the contact and supply isnt so good to the ignitor
and its not working i assume the ignitors board isnt being supplied
or the switching to energise the spark isnt working
or the ignitor board has failed
you can also attach images from a camera
use macro mode and natrual light
or non macro mode
pics are good
more info and some checks
Jun 04, 2015 | Water Heaters
Green light on unit not lit, no test startups as
Check the battery condition, and charger. Check also the fuses in the transfer switch (note they are line voltage so maybe call an electrician)
Oct 26, 2013 | Generac Honeywell 20KW Standby Generator
Battery not charging
Sounds like it could be two things with that, first look at the battery symbol, is it flashing orange or is it green. If its flashing orange means you have a bad battery, if its solid green all ok, if its switching between green and yellow its charging. if the symbol isn't lit at all it doesn't detect your battery and try to remove and reinsert battery. Next look at the plug light, is it green?
Dec 16, 2012 | Lenovo IdeaPad Z560 Notebook
All I get is static when I use my T V Ears. Everything hooked up properly, have new battery. What's wrong?
Hook up your TV cable to Bell , Rogers , or satelite box , make sure cable is connected good.
Feb 27, 2012 | TV Ears 10241 Professional Listening...
Hi. I am charging up my battery for my Harley and am using an oxford oximiser 600, but have lost the instructions. I would like to know what the two lights are to either side of the four lights. They...
You have the four coloured lights to show battery state Red - irrecoverable; Orange - 3 to 6 Volts in the battery, Oximiser will attempt recovery; Yellow - 6 to 12 Volts in the battery, Oximiser will charge and and optimise and Green - Full charge, about 14 V, the Oximiser will maintain the charge.
On the left of this you have a Green light to show that the Oximiser is connected to the mains and on the right you have a Red light to show that you have connected the charging leads thewrong way around, i.e. the positive charging lead is on the negative terminal and the negative charging lead is on the positive terminal. This light should be off.
Sep 29, 2010 | Harley Davidson FLSTC Heritage Softail...
I am able to use this router in wireless mode but cannot get it to work when hard wired to the router. What setting do I need to check?
When you connect the computer to the router with the cable, make sure that it is connected properly and there is no loose connection. Also if you are connecting the computer to the port number 2 on the router then make sure the port light will lit up.
Proper light should lit up.
Check the IP address on the computer.
Check if there is no static IP address on the computer. If there is a static Ip address then set to obtain IP address automatically.
Click here for step by step instructions
Mar 09, 2010 | D-Link DIR-625 (790069292637) Wireless...
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Not charging
It sounds like Amazon might have sold you a defective charger radio shack has a universal charger for your battery. Around 49.00 I got one and it works great I would first have you battery tested by a place like batteries plus to make sure yours is good.
Mar 08, 2008 | Casio Exilim EX-S600 Digital Camera
Sennheiser HDR 120 Consumer Headphones Logo
4,541 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
