Check and clean your spark arrestor located behind a diverter plate on outside of muffler. You'll need a #25 Torx, or one slot screwdriver and wrench to take the plate off. Clean it with carb cleaner and wire brush and re-install. If this screen gets clogged, it could lead to fuel spray coming out of carb throat. Clean and re-oil the sponge filter while you're at it. Hope it helps!
Since the air from the air filter does not go through the carb, the carb cleaner will not either. If you remove the carb and spry all of it that you can get to, you may get the plug. If you were to open the carb and go through it and clean it you would need to get new gaskets and maybe that will do the job. You may be able to adjust the carb. There is a "hi" and "low" setting. Try adjusting the "hi"...Lee
