The anodes when attached directly to an unpainted area of an aluminum hull will protect any part of the hull that is not electrically isolated from the anode.
My answer is a Yes. Because I have had an aluminum fabrication done from Bayview metals at Ontario. I have done it long back and I never needed any maintenance work till now. It has a great advantage of no corrosion. So your dad is right. Let him go for it.
Without knowing the make & model of your ceiling fan, I can't answer exactly, but I'll do my best.
You probably have black, white & green wires. Green is always ground, which means it gets attached to the metal box or ground wire you are connecting to. Since you're connecting (presumably) to an AC current, you should try to connect black to black and white to white. If you have some other colors, it shouldn't really matter.
HOWEVER! If you're connecting aluminum to copper wire, you should not use the regular wire nuts. Copper is much softer than aluminum. Instead of winding around each other, which holds the wires well, the copper will wind around the aluminum. This means the copper could slip off the aluminum, exposing wires. (translation: BAD THING!!)
Copper + aluminum = No wire hangers... err.... No wire nuts.
Aluminum boats are easier to maintain, will last longer than fiberglass, and are easier to repair. You can also bump into things without causing damage like you would to a fiberglass hull.
The only real advantages to fiberglass are that it looks better due to the gelcoat finish, providing that it is maintained, they also feel more solid in the water due to the extra weight, and they tend to ride better and are quieter than an aluminum hull.
One other consideration is whether you will operate it in fresh water or salt water. Salt water can lead to corrosion problems on an aluminum hull if you leave it in the water. Fiberglass doesn't have that problem, but you can have a problem with blistering if you leave a fiberglass boat in the water for long periods, especially if you don't use a bottom coat of some sort.
If you do opt for an aluminum boat in salt water, just make sure that you spray it down with fresh water and wipe it down with a soft towel whenever you take it out of the water. This is actually a good practice for any boat, aluminum or fiberglass.
The transducer for your depth gauge will not work through an aluminum hull. A drilled through-hull transducer or a transom mount transducer are your options here.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
Transducer will stop getting readings if it gets air under it. If it's lower surface is too much above or below the bottom of your boat, this can happen.
Well-made aluminum canoes are rugged and most dents can be punched out. They are the ultimate no-maintenance canoe. Even when left outdoors all year, neither rain nor snow affects them and they will not take on weight with age. They are rigged with flotation air tanks or foam compartments to render them unsinkable. On the downside, aluminum canoes are noisy, tend to cling to (rather than glide over) rocks, and conduct heat and cold. Most aluminum canoes carry their beam well forward and aft so that they push rather than cut through the water. This hull design, however, makes them initially more stable and increases their carrying capacity.
