I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
When I turn on my DMC-FX07 none of the buttons work. The zoom doesn't work, the menu button doesn't work, the flash settings dont work.
I have the exact same problem. It freezes everything. Power comes on fine but it won't do anything but turn on. Someone must know the answer.
When I turn on my DMC-FX07 none of the buttons work. The zoom doesn't work, the menu button doesn't work, the flash settings dont work. It won't switch from current picture when in viewing mode. I have tried all the picture wheel settings and every one is frozen. I have trie pushing and holding every button and removing and replacing and recharging the battery several times. When I replace the battery the autofocus works but then it freezes (when in heart mode) with the backlight indicator on. It won't take any picture or movies at all.
exact the same problem, with the exact same model, and in Argentina the service wants to charge me U$S100 to fix it!
Just discovered the exact same problem today. None of the buttons work after poweron. At poweron the camera starts by zooming fully in and stays there with no reaction on any button.
