Question about Sony DAV-S300 System
I need replacement speaker leads for my hcd-s300 will the dav-s300 ones fit?
Has the dav-s300 model replaced hcd-s300?
6ya staff
SOURCE:
petraman7
Scott Frye
  • 1175 Answers
SOURCE: how to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Posted on Jul 07, 2008
Anonymous
SOURCE: sony DAV-S300 NO SOUND
Had the same problem. I traced it to the main sound processor chip. This is a large surface mount device. The easiest (and cheapest fix) is to search e-bay for a broken DAV-S300 but with working sound. The one I found has a broken disc tray and was generally scruffy. It was cheaper than buying the chip itself. Then change the main PC Board.
Posted on Jul 16, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: SPEAKER WIRE CONNECTORS
You need 5 Cord (wires) Connection to attache all speakers.
You can have all 5 cords in one package or each cord individually at Sony Accessories.
Please write model number DAV-FR1 in search box to get result on above web page.
Details of wires required.
182724411 1 BAG = 5 CORDS approx $43
179146811 CORD, CONNECTION approx $10.30
Posted on Nov 10, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Posted on Nov 30, 2008
Anonymous
SOURCE: COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Posted on Jun 04, 2009
I need to find speaker connectors for Sony DAV S300
Check eBay "sony DAV-S300" check the 'include description' box. Several there.
Jul 16, 2011 | Sony DAV-S300 System
My hcd s300 has stopped producing sound. I have tried muting and unmuting. Any help would be helpful.
Have you looked at page 57 of the manual?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 28, 2011 | Sony DAV-S300 System
The sound stopped working. I have checked all the leads. Everything seems fine. Been working for years. Any ideas?
One source or many? Could be the source.
Make sure you have the correct input selected and MUTING is not on.
If the product is protecting itself disconnect all but one front speaker and see how that works out. If it starts working you need to isolate which one is/was the problem.
Dec 30, 2010 | Sony DAV-S300 System
Can the dav s300 speakers be set up without plugs?
Yes, they can. The lead with the color band is +
Feb 07, 2010 | Sony DAV-S300 System
Sony DAV-S300 volume is unchangeable from either remote or knob. Any ideas?
Is the sound coming from the speakers you have installed, or from the speakers on the TV itself?
Dec 19, 2009 | Sony DAV-S300 System
Hi , i have a sony dvd-surround sound system that works fantastic! i lost my remote for it in my move.i am trying to find a replacement remote.....any idea where to buy or order one? model-hcd-sb100
Required remote for DAV-SB100 (HCD-SB100) sound system is ..
988506939... REMOTE COMMANDER (RM-SS220)
Please search over internet for price.
Thanks.
Dec 03, 2009 | Televison & Video
Sony DAV-S400 Laser Unit Replacement
where did you get your laser from as i need one for my sony hcd-s300
Nov 27, 2008 | Sony DAV-S300 System
Nov 10, 2008 | Sony DAV-FC8 System
Oct 15, 2008 | Sony DAV-S500 System
Sony DAV-S300 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
