Hello
You Problem with flex or display or camera.
You can buy it here.
Substitution is possible independently.
Panasonic SDR T70 display
Panasonic SDR T70 flex
SOURCE: Wierd colours on LCD screen.
Check LCD ribbon cable. 99% LCD ribbon cable is defective. Replace LCD ribbon cable.
SOURCE: white screen
I don't have a solution, but I have the same problem. Actually, I have that problem after I get it to turn on. The first part of the problem is that I can't get mine to turn on - with a fully charged and fucntional battery - without removing and rplacing the battery and switching on/off numerous times. Then, when it does come on, i get the exact white screen problem you decribe in your post above.
SOURCE: help,,, camcorder when turn on says "to service " and turns off
after reading the above solution, a few swift taps to the bottom got it to work. I guess it is just be careful, but if it happens - show it some tough love
SOURCE: Panasonic PV-DV103 Playback Problem
check ur recording mode it may be on snapshotmode change it. or clean ur cam head
