SOURCE: walkie talkie problem
That would depend on what is wrong with the radio(s) Most GMR radios are through away's. The average bench time for a repair on a single radio is anywhere from $70 - $100 dollars and thats not including parts. Some manufactuers have a flate rate charge to repair thier product. you might try that avenue.
Patrick
SOURCE: I need to download a how-to manuel for my walkie talkies
http://www.uniden.com/index/manuals_results.cfm?cat=25
SOURCE: hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
SOURCE: walkie talkie wont communicate
um if it dont transmit then take it apart if you know how to or
let me see it
i can fix eny walkie talkie
SOURCE: I took out the rechargeable batteries (replaced
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
