Computers & Internet Logo
Posted on May 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless keyboard not working
My kboard doesnt work, i have tried all the steps from the hp support but my kboard snt working. its an hp pavilion s3041la and i have all the drivers and ll taht stuff. my mouse works well. it suddenly stopped working yesterday but I dont know why. my kboard is supposed to be in ntact with my pc through my usb receiver, though it only receives mouse signl now. please help me. thanks for reading
  • chavador_198 May 19, 2009
    Hey, thank you, first I tried a used set of batteries but it didn't work, then I tried with a new set of batteries, and it worked. Thank you very much
Abhisek Das
Level 2:
  • Expert 115 Answers
  • Posted on May 19, 2009
Abhisek Das
Expert
Level 2:
Answers
115
Questions
0
Helped
58826
Points
351
Well,the problem is small,,first check with a different set of batteries on the keyboard,after tats done,press the connect button the wireless receiver and after 5 sec on the connect button on the keyboard,if the connection to the mouse gets disrupted then press the connect button on the mouse.the last step u can try changigng the usb port of the receiver,,,i beleive there is no other troubleshooting steps to this issue,,if still no go,,call up tech support and replace the whole set
best of luck,,keep me posted ,giv a good rating
Hp pavilion a1710n doesn't send to printer. Goes through every step,doesnt send. My laptop workds with the printer.
A few things come to mind. Are you sure the printer isn't a D4160??? The C4160 was sold in England. Anyways...
First, when you hit print a box opens up. On the top of that box make sure your printer is the one selected. It will have a green checkmark by it.
Second. Make sure the USB cable is connected between computer and printer. The Hp pavilion a1710n doesn't have a wireless network chip so it will need the USB cable connected for it to print.
I assume your laptop prints wirelessly and that is why it works and the HP does not.
Good Luck
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
My hp netbook keypad is ocked, i cant type anything
maybe reseat the keyboard if a "switch it off and back on" does not work
http://h10032.www1.hp.com/ctg/Manual/c01683469.pdf
shows you how to remove keyboard (and part number you can ebay for a new one maybe)
you should plug in a usb kboard to test its just the built in kboard....
hope that helps
Keyboard doesnt work at all, its wireless
Install the driver for that wireless keyboard and try again.
if it won't, then chage the battery on the Keyboard.
again if it won't then the issue might be with the Keyboard hardware.
1helpful
The symbols above the numbers on my keyboard just stopped working. Would this be a hardware problem or a technical one. I am using someone else's computer to send this message as I am unable to get into my...
Hi, I'm guessing you have tried using both the left shift and the right shift?.
if one works and the other doesnt I'd say the keyboards stuffed.
If its a funky multimedia keyboard there perhaps may be some key/button to enable/disable shift and or special characters, but I have never seen a keyboard like that.
Do all the numbers and alpha characters work, its just to sybols about 1 to 10?.
This is a wireless keyboard?
Maybe reset the keyboard, normally the base unit and the bottom of the kboard and mouse have a reset/reconnect button, worth a try but I suspect it wont help.
Trying new batteries probably wont help either but probably worth a try.
Failing that, I'd plug in an old usb/ps2 keyboard into your pc and see if that works OK (you'll need to reboot first if its a ps2 keyboard), just to rule out any strange software issues.
All that said however, I suspect you may be looking at a new keyboard.
I do think its worth trying the above first though.
Good luck.
joshAU
Sömê ofmy letters dont work on kboard
the langauge settings may not be right
uninstall it and start all over again but pay attention
if this doesnt work try the logitec site
Hp Pavilion dv1000 laptop wireless connection doesnt always work? Sometimes it shows that a connection is available but it wont connect. Sometimes it works fine but drops out right in the middle of what...
you might have to review the driver version of your wireless. try to check if there are updates that might fixed the bug. go to my computer, right click, manage, device manager, network adapters - under it move your mouse on top of the wireless, right click, properties, driver and check driver version and date. then go to your hp pavilion product support http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432999&taskId=135
and look for new version of network wireless driver might have. let me know if this doesnt fix the problem.
Driver for hp dv1000
http://www.hp.com/#Support
Step 1 mark: "Download drivers and software (and firmware)"
Than follow instructions.
4helpful
2answers
Replace HP dv9000 keyboard
This is probably the closest model to your HPdv9000, click on the link and read on! http://www.insidemylaptop.com/remove-keyboard-replace-memory-hp-compaq-nc6400/
Good luck and have fun!
HP Pavilion zv6000 Notebook PC keyboard replaced
Probably the keyboard you got is defective. I have seen buttons working in very bad conditions. When a key doesnt work or several is bad news.
Try to get a replacement. Since you have already reseated this simply check if the flex cable is properly locked, (ear plugs or similar) and not moving.
Grand Canyon Tech
Grand Canyon Tech
