Wireless router just installed along with a new blue ray player on a new Vizio 47" tv Netflex will not connect to the tv
SOURCE: i have a linksys wireless g broadband router and i
Set up your router as normal so that it connects to the Internet and you can use it with a Lptop and then set up the player to connect to that WiFi cell. Should be straightforward. Just be careful that the level of encryption you choose for the WiFi (WEP/WPA) is compatible with the Player. You don't give any specific model for the player so cannot check for you.
SOURCE: blinking lights? not connecting
Is the power light blinking??
checked the power adapter and make sure that it is properly plugged in and working fine.
if it is ok, press the reset button on the back of the router for 1min, let go of the reset button and power it down for another min. if lights are still blinking, it may be defective
SOURCE: I am installing this wireless
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
SOURCE: I'm trying to connect a Samsung BD-C6500 Blu-ray
Here is the manual (http://downloadcenter.samsung.com/content/UM/201001/20100120173529671/BD-C6500-0120.pdf) ..I typed 192.168.1.1 into my internet explorer address bar and it went to my router options from there I assigned a port
SOURCE: How do I retrieve my router password so I can
hold in the reset switch on the router until it flashes and the router resets to its default user and pass which are
username: leave blank
password: admin
