Video Cameras Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to transfer video from JVC GR-770U Camcorder to my compute
How do I transfer video from my JVC Model GR-770U Camcorder to my computer. Do I need special JVC software?
Anonymous
Level 3:
  • Master 431 Answers
  • Posted on May 20, 2009
Anonymous
Master
Level 3:
Answers
431
Questions
0
Helped
147204
Points
1209
Hi I am Vortash according to the manual for this unit available on http://www.safemanuals.com the unit is quite capable of downloading to a computer but yes it does require the correct software to do so .. you may find this is available from JVC support as a download .. it says that you can download to a usb terminal or a Rs socket with a compatible retail software .. hope this helps Regards Vortash
I can't figure out how to download video from my JVC GR-D90U Camcorder to my computer through it's usb cable. It is a mini DV camcorder that uses mini video tapes.
From the JVC manual "This camcorder can transfer still images to a PC via USB". There is no mention of video transfer via USB so it seems it is not supported.
How can I transfer from my JVC GR-FXM40EK to PC?
JVC GR-FXM40EK is analog camcorder that can not be connected directly with computer because computer needs digital video format to save the file so connect USB 2.0 Video Capture Device in computer and plug camcorder AV wires in that device that will digitize the AV signals of analog camcorder and computer will save it in your selected folder on hard disk.
Hope this will help.
Do i need software for jvc mini camcorder model gr-d347u
If you are asking about software for transferring your tape to your computer, your computer should recognize when your camcorder is plugged into it and it will install the appropriate driver.
Attached is a link to the user manual. You will need to refer to the "editing" section. This should have all of the instructions that you need.
http://static.compusa.com/pdf/jvc-gr-D347U-manual.pdf
Hope this has helped you.
www.austintelstarservices.com
Need drivers for jvc gr d33u camcorder
You don't need a driver to transfer video to your computer. You do need software that works. You can use microsoft movie make to transfer it. Also here is the user manual for your camera as well:
http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx
http://resources.jvc.com/Resources/00/00/95/LYT1196-001C.pdf
thank you and enjoy,
Lee
I need transfer my videos to my computer
If you are looking for cables for JVC GR-D370 camcorder, then click JVC Accessories Store to see list of related accessories.
And if camcorder is different model and make, let me know to find out for you.
Thanks.
2helpful
Downloading Video to my Computer from a JVC GR-SXM920
You need a video capture card that supports analog inputs. Connect the video and audio out jacks from the camera to the computer. You will need some sort of software also. The Movie Maker software that comes with Windows XP would work.
The little cord that came with the camera will not transfer the video.
I need a usb cable for my jvc gr-d22u video camera
In my opinion, Firewire is the best method for transferring video to your computer from your camcorder. The JVC GR-D22 and Dell Inspiron 9200 both have firewire ports if I am not mistaken.
3answers
My camcorder
You can transfer video from the camera to your pc by using an i.Link connection if your camera has it or you can use the supplied usb wire to connect it to your pc and transfer the video that way. If you do not have the cord it is easily obtainable at any camera repair or sales store.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
