These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
SOURCE: The TV turns itself off after 14 minutes
Sounds like maybe you have a sleep timer activated? There should be an option to reset the tv back to factory reset, this might help you.
SOURCE: I have a Toshiba REGZA
it is fixable you have the trouble in the power supply try replacing the regulator.
SOURCE: timer rec red light flashes 3 times
the problem is the main power board you can ither change the whole board or change the STR-W6765 Primary Switching Regulator.
SOURCE: Hi. I have a 42"
The best solution to this problem is to call Toshiba directly and ask for assistance. Any TV repair company/shop will probably charge you an automatic fee to assess the problem, and then tell you it's a very expensive fix. With just the model and serial number of your TV, an easy 5 minutes will get you the answer you are looking for.
