Washer fills, dispense soap, drains, flashes oL code (skips washing cycle). Not overloaded. Will complete wash cycle without soap & clothes. Will drain & spin with clothes just does not wash! Adjustable legs are stable. Unplugged power cord (hoping to reset electrical board), drain hose checked, would love an answer ;-)
SOURCE: Maytag MAH6700A
Dough, these models have had issues with the wiring harness that connects to the motor. UNPLUG THE MACHINE!! Pull the unit from the wall and remove the rear panel, 4 screws back there. On the rear of the tub about the 5 o'clock position, you'll see the motor. See the wires that connect to it? Check to make sure they are properly seated in the connector and that the connector is properly, firmly seated to the motor. Then replace the panel, push it back to the wall and plug it in. Now, for the diagnostics mode and "quick spin test". Press "chime" and "extra rinse" buttons at the same time for 3 seconds or until unit beeps. This will put it in Service Mode. Now press both the "delay start" and "rinse and spin" keys at the same time. The unit should initiate a spin test which will ramp up to maximum speed and hold that speed for 2 minutes, then ramp back down. Exit Service Mode the same way you entered it, above. After doing these tests and checks, post back and let us know what happened.
SOURCE: Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
SOURCE: Maytag Neptune Door Locked
Hello , I can help , this unit will not work without locking the door , the wax motor in the latch assembly has failed , I have replaced a lot of these , usually it is best to replace the entire latch assembly , this is what your plastic lock string connects to. you can try to replace just the wax motor first due to cost difference. you can find it in the latch assembly it is commonly maroon in color and 1 inch rectangular. please ask any other questions you may have and tell me how this works out.
Phil
SOURCE: Maytag Neptune Error COde "nd"
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
SOURCE: Maytag Performa Washer niosy during wash-cycle. Spins OK and without any noise.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues. Check this link : For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
