Mi impresora marca 52.0 error - Indicates a problem with the internal Laser Scanner.
The Laser scanner provides the image onto the toner cartridge drum, if the scanner stalls or fails to turn an error is reported, in some cases the DC Controller may be at fault.
1) Power cycle the printer.
2) If the error persists, replace the laser scanner.
Part Number Laser/Scanner Assembly RM1-2555-000CN
Laser Printer Parts www.partsnow.com
Hewlett Packard P3005 52.00 Error - Indicates a critical Laser Scanner error has occurred.
Loose cable connections or faulty laser scanner.
*** The Laser Scanner should only be accessed by qualified individuals. ***
Resolution - Power cycle the printer - if the error persists, change the scanner.
Part Number Laser/scanner assembly RM1-1521-030
