If the tv has a built in dvd player, you should simply be able to put a dvd in the drive and the tv will auto-switch to the dvd player.
If you have an external dvd player, ensure it is plugged into the tv.
On the remote you should have a button that says either "Source" or "Video"
Press this button until the video input your dvd player is plugged into is highlighted, then press "OK" or "enter" (some tv remotes have one button that highlights and also selects the input)
You may also press the "Menu" button and check in the "video" section if your tv supports "Auto input switching" This will allow your tv to automatically switch to whichever device (dvd player, game console) is turned on while the tv is on.
Please provide make / model of tv and possibly dvd player for further help.
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
I'm not sure, but, if you use the channel down button on the television (below channel 2), the set may go to the video inputs.
If not a local retailer should have an inexpensive universal remote that would work on this set and have an input or tv/video button.
If you use a cable box, the remote can be programed also.
If you need more help, reply to this post and I can come up with more solutions when I get to my shop next
