Question about Cardiozone Supersport Hr Club Commercial Treadmill
Motor will not turn
1) Was using the treadmill when suddenly it stopped 2) Found that the fuse was busted 3) Replaced fuse and all the lights came on but motor will still not turn on
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Your controller is shot. Replace your controller
Posted on Jan 04, 2014
6ya staff
SOURCE:
I have a vivotion treadmill, the display works but the treadmill belt has stopped turning. Any suggestions?? Is does the motor have a desperate fuse ??
It might be a fuse. A friend found his motor was overheating and stopping very quickly. Think it was worn bushings or bearings. He replaced the motor on his.
Jan 03, 2015 | Exercise & Fitness
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
2)Alternative:
Jul 15, 2013 | Exercise & Fitness
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
2)Alternative:
Jun 19, 2013 | Exercise & Fitness
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
Step 1:
you will have two alternatives:
ERROR CODE # 7
2)Alternative:
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
Jan 04, 2013 | Sportcraft Exercise & Fitness
I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
2)Alternative:
Nov 15, 2012 | Exercise & Fitness
Reebok edge 2.2 treadmill stopped suddenly then blew fuse
1) Inspection if the fuse is the correct Amper and Voltage: example: you can not connect any FUSE less if they use 10Amp, not use 5 amp, or 15amp. That situation is delicated.
2) clean contact fuse, and retight the clips of the fuse, and tight the wire to the clip of the fuses.
3) The motor is Short or ground: Test with Some DVOM, maybe the winding is short,and need maintenance: brushes, grease, and clean, bearing. or the winding is faulty.You can go to some Shop for repair electrical motor.
sincerely.
E.CUADRA
Nov 02, 2011 | Exercise & Fitness
My treadmill is brand new and not coming on
Hi ispeaktobefr,
Please check the following:
1. Please make sure that the battery is fully charged, because it won't work if not.
2. If the motor turns slowly then your motor is ok, if not the motor is bad and would need to be replaced.
3. If the motor is ok then the motor controller ( the board with the metal ) is malfunctioning and would need to be replaced.
4. You may also check the fuse.
Hope it helps.
Thank you for using FixYa.
Jul 14, 2011 | Weslo Cadence 60 SE Treadmill
Stops running
LED Blink Patterns on the Control Board Treadmill Treadmill Maintenance How To Lubricate Treadmill Belt
Try to do this steps in order to fix it.
However if the problem persist.
Time to replace the Controller board Motor.
This board has 3 power supply control:1) Console Board 2) Elevation Motor 3) Main Motor.
One of IGTBs is faulty.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 01, 2017 | Proform iLog 750 Treadmill
Cardiozone Supersport Hr Club Commercial Treadmill Logo
110 people viewed this question
Top Cardiozone Exercise & Fitness Experts
Jesse Garza
Treadmill Repairs...
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
