Question about Technics SL-1200MK2 Turntable
Technic 1200 mk2 turntable wont spin
I bought a used technic 1200 mk2 it turns on but the turntable wont spin.. anyone know what it could be .. i replaced the start stop button, also the regulators still nothing please help thanks
  • 3 more comments
  • Anonymous Nov 01, 2007
    yes
    YES
  • rmeisters Jan 01, 2009
    I believe I have the same problem. The gets power but the platter won't spin. I took it apart and examined the stop/start switch and it appeared to be fine.
    On my other sl1200mk2 I took the platter off. When I held a screw driver to the outside of the electromagnet and pushed start I could feel the magnetic field. On the broken table I did the and could not feel it.
    i hope there is a DIY fix for this.. I'm broke
  • Anonymous Jan 25, 2009
    Yes it powers up! all lights turn on pitch power ect..I replaced the on of switch from the inside.and one of the little chip things,But still no spin
  • Tim Hadley Mar 25, 2012
    It's usually the fuses under the platter.
  • 515 Answers
Need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Posted on Nov 02, 2007
  • Linda Torrence
    Linda Torrence Jan 03, 2014
    Hi Terminal Optic, Yes it gets power. It will spin if you move it manually. I don't hear it trying to spin. I never thought about the ON/OFF knob. The one on the outside moves and of course the whole unit is connected to my sound system. I guess I'm going to have to buy a power manual as this unit is over 23 yrs. old, but has been kept in perfect condition and not abused. So your saying that the PC board could have just went bad, all by itself? How much does it cost to buy a new one that is just as good or better than this one? I sure appreciate your help. I'll look into it.
    New Friend:
I have the same issue, power button is fine, pitch light, pop up light all work fine, just no drive to the turntable, could it be the an6675 requires replacing?
I have read this on another solution.
Posted on Aug 13, 2012
  • Linda Torrence
    Yes, my pitch light comes on also, pop up light, just no drive to the turntable. It all gets power also, you can hear it when you turn it on. Wish my brother-in-law lived here now.
  • Tim Hadley Aug 11, 2014
    There's a 20mm fuse under the platter that often blows . For no particular reason. Replace it and voila.
  • Technics Master
  • 924 Answers
This is a Direct Drive turntable. It can have a lower supply issue, microprocessor(computer inside your technics) or the drive circuitry. This will not be easy to resolve, and will require professional service. If you are interested in having your technics repaired, please visit my website at audioserviceclinic@gmail.com. Thank you.
Posted on Dec 08, 2015
    New Friend:
I have the same problem, lights are fine, at first it needed a push to start spinning, and now it is not spinning at all. Thankyou
Posted on Jul 08, 2015
  • Samuel Bartolo Jul 08, 2015
    Novelist:
    Champion:
  • 382 Answers
Does the entire chassis get power?
Pitch light, pop up light, strobe light, 33/45 light?
Posted on Oct 28, 2007
6ya staff
SOURCE:
Technics 1200 fault where both the 33 & 45 buttons remain lit, the platter spins at super speed,start stop button doesn't work and the red light is not on
Did you try to de-assemble and clean the contact of this button with contact cleaner, take care to not shoot on rubber parts if you have near the contact, it would blown up !
Apr 28, 2014 | Technics Audio Players & Recorders
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
Apr 28, 2013 | Technics SL-1200MK2 Turntable
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
WHY DOES MY TECHNIC 1200 MK3 GO IN REVERSE IF I HIT THE START BUTTON TWICE?
There is a mod you can do to the 1200 to make it spin in reverse with a double-tap on the start / stop switch - exactly as you're describing. Likely, the previous owner installed said mod. It's awesome, embrace it.
Jul 29, 2012 | Technics SL-1200M3D Turntable
I have just bought 2 1200 mk2 ,the seller has told me the start/stop buttons where powered by a mixer and will either need to be reconnected this way or reconfigured is this a problem??
who ever told you that is a ****, start n stop are tied into the power of the turntables motor etc. if you plug the turntable in turn it on n hit start. it should start. if not who ever sold it to you made a BS lie to get rid of them cause the motor was burnt out. start n stop have nothing to do with the mixer what so ever. so try just hooking up the turntable and turn the power on. see if anything lights up then his the start button and see if the platter starts to move if not its your motor.
May 30, 2011 | Technics SL-1200MK2 Turntable
Technics 1200 mk2 just powered down and wont come back on
THERE ARE FUSES UNDER THE PLATTER AND BLACK COVER,REMOVE GLUE FROM AROUND REGULATOR DRIVER TRANSISTOR ON PCB.
Nov 12, 2010 | Technics SL-1200MK2 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
styluscity@gmail.com
May 10, 2010 | Technics SL-1200 Turntable
Has anyone else had the problem with their 1200 technics,where the turntable doesnt spin,it judders back and forth??
1, The regulator circuit has failed, usually transistors Q2, Q3 and zener diode D3.
OR
2, The drive I.C (I.C101 / AN6675) has failed, this can be natural failure but also can happen if the deck is turned on and started with the platter removed.
Free Technics SL1200 / SL1210 service manual available here :-
http://www.technicsdjuk.com/
http://stores.ebay.co.uk/methleykev
Dec 27, 2009 | Technics SL-1200 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
2,993 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
