My 5.0 snowblower starts one pull if I spray starter fluid in carb. I changed the fuel and cleansed carb bowl still won't stay running put in a little gas line anti freeze but no help there is fuel getting in carb bowl. Any additive I can put in fuel so I don't have to take carb apart? Thanks
Or just put some SeaFoam in the fuel and oil, let sit for ten minutes, fire it up and leave running for another 5 minutes...done...
Try taking the fuel jet out and blowing out the little hole that goes through it. Just a little bit of dirt will not let the engine run. While you got the jet out take the fuel bowl off and clean that as well. Be careful and don't mess up the float when you do this as sometimes they are hard to get back in. I find a lot of small engines I get in has a dirty fuel bowl and jet That's all i do in a lot of machines to get them running again..
SOURCE: my yardmachine snowblower won't stay running. It
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
SOURCE: mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Testimonial: "Thank you for your very helpful advice and detailed insructions as to what to do to correct this problem with starting my mower. runs like new now. Thanks again for taking the time to help me out. Grump."
SOURCE: Briggs & Stratton 6hp yard machine with 21inch
The fuel bowl needs to be removed and a new float and needle needs to be installed. The float "floats" in the gas bowl raising the needle, letting fuel into the carb. The repair kit cost about $5 and easily replaced. The float is attached with a pin and the needle fits on the float.
SOURCE: Well my yardman has fuel to the carb and will
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
SOURCE: HI there, I got
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
