SOURCE: blue keys 2
If you press the Fn and Num Lock at exactly the same time, it usually won't work. Hold down Fn key first, then press Num kock. See if that works.
SOURCE: numbers locked in on Dell Laptop
Look for the Num Lock key written in blue, press the FN key and press it. It will turn off the number keypad.
SOURCE: right hand side of key board displays numbers
Your bios probably is set to use the embedded keypad when the numlock is on. you can set it to numbers only when you press the FN key
SOURCE: my dell laptop types numbers instead of letters on
HI,
If you Are writing numbers instead of letters when you press the
keyboard of your laptop and you must hold down the Function key (Fn) to
write normally.
This is due to the fact that the digital lock is activated. To solve
this, simply press the Fn+Numlk or depending of the model, press the
button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
