Televison & Video Logo
A
Anonymous Posted on Jan 16, 2018
Toshiba 32a14 I have a 2004 Toshiba Model 32A14 TV that I am trying to control with a GE 24993-V2 remote. I cannot get any of the codes specified in the manual to control the TV. I have tried several times and had another technician try to program the remote as well. We also attempted the auto code search as well.
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on May 05, 2008
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
A
Anonymous
  • Posted on Aug 31, 2008
SOURCE: RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
there is no "code search" button on the RCR3273???? can anybody help?
Anonymous
  • Posted on Nov 08, 2008
SOURCE: GoldStar wireless Remote Controller Code for Toshiba TV
need codes for innovage jumbo universal remote
dvinnedge
Dale Vinnedge
  • 35 Answers
  • Posted on Nov 29, 2008
SOURCE: Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Anonymous
  • Posted on Dec 06, 2008
SOURCE: need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Toshiba 32a14 codes
It weighs [111] lbs
Codes to check are, 2086,2091,2004,2007. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Need the code for sharp tv its a ge 24993-v2 1145 remote
Look for the manual that came with the remote. In the manual you should find the various Codes used for different TV's. Each make (TV) has several codes to offer and if you are lucky, you may just select the correct code 1st time around. If not, try all the codes, one after the other until you get one to work.
2helpful
2answers
I have a GE universal remote RC24993-C and I need the code to program a Sanyo tv
necesito el codigo del control universal ge rc24993 para una tele tohiba
I have a toshiba 32a14 TV and an Auvio universal remote. I can get the remote to turn the TV on and off but I can't get it to change the input to the TV
Tv universal remote have it limted to it used and operations,only operate the basic only like power on/off and channels up/down also volume up/down that about it.The tv input video 1 or 2 for IN tv to used are tv personal funcstions only for the tv original remote control only have it functions for.Try the website Remotes.com to buy the tv original remote.
I need the code of my controller GE 24993 to program my TV RCA
Hello
Setup codes for RCA TV with GE remote control are:
000 003 004 005 007 009 011 015 048
082 092 094 096 098 101 102 103 107
113 125 129 167 179 187 188 191 194
OK.
1helpful
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
