Washing Machines Logo
Posted on May 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not drain i installed new pump and belt and it still wont drain a drop spins great
Water will not pump out. and i installed new waterpump but it still does not drain a drop of water its a mav6200aww model and has been very dependable for the last 7 years
  • 4 more comments
  • barb_kenny May 21, 2009
    sir, is there any other switches or valves between the tub and water pump and if not then with the new water pump and belt it should just pump water out unless something is clogged in drainline but if that was the case wouldnt the drain tube overflow on the floor,? its a mav6200 maytag washer
    yes it will because when i diconnected it from the pump all the water came rushing out and i caught it in a large bucket
    the water from the tub came rushing through the blcak plastic pipe that was connected to the water pump i caught this with a lg pail.
    it seems there may be a clog in the drain line in the wall but i would think that it should backup and overflow?
    i put it all back together so i cant blow through the drain line ,the drain hose is duck taped to the drain pipe so it would not fall out but i sealed it good and i did not want to take tape off and all that but i guess i donrt have a choice
    should i take drain line out of drain tube then fill tub and lay hose on floor if it drains does that meen there is a clog in drain tube in the house plumbing?
    at this point i think i put a new pump and belt on for no reason as the old one looked good although it make kind of like a tinney,clank, sound when the washer went into the drain cycle
    thank you for your help and time GOD BLESS
  • Anonymous May 11, 2010
    HI, Try blowing through the drain hose and see if you can hear it bubbling inside the tub. You might have to remoave some of the water first. When you had the water out to change the pump, did you check the tub outlet to see if there was anything in it?
    Just some ideas.
    I hope it helps.
    Vic
Anonymous
Level 3:
  • Master 1,136 Answers
  • Posted on May 21, 2009
Anonymous
Master
Level 3:
Answers
1136
Questions
0
Helped
354493
Points
4025
As long as the washer is running in the spin cycle, it should drain. The plug I am talking about is in the machine hoses. Sometimes a belt can jump off the pump pulley and not spin it fast enough. If you set the hose in a bucket or floor drain, will the washer drain?
There are no other switches that control the pump.
  • 1 more comment
  • Anonymous May 21, 2009
    If you still have the hose off, try blowing through the drain hose that is attached to the pump.
    Is the drain hose from the washer fastened solid to the wasll drain? Some people clamp the drain hose to the wall drain.
    This model is known for the pump going bad so, even if this wasn't the problem, it probably would of needed changed in the future. Yes, remove the hose and seen if it drains with water in it. The duct tape could of sealed good enough that you couldn't tell if the wall drain was plugged.With the tape off, you might just leave the drain hose in the wall drain and after you fill the machine, start the drain cycle and see if the wall drain starts to overflow.
    You are very welcome. Please feel free to rate my answers so the others and myself know how I am doing.
    Good Luck
Where is the waterpump on 2003kia sorento lx ?
Water pump is Timing belt driven. It is below the Camshaft sprocket, in the timing case. If you want to repair/replace it here are the instructions.
COMPONENTS
REMOVAL
  1. Using the drain plug, drain the coolant.
  2. Remove the drive belt and the engine coolant pump pulley.
  3. Remove the timing belt cover, the auto tensioner and idler pulley.
  4. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  5. Remove the engine coolant pump mounting bolts.
  1. Remove the engine coolant pump assembly from the cylinder block.
INSPECTION
  1. Check the engine coolant Water pump for cracks, damage or wear, and replace the pump assembly if necessary.
  2. Check the bearing for damage, abnormal noise and sluggish rotation and replace the pump assembly if necessary.
  3. Check the seal it for leaks and replace the pump assembly if necessary.
INSTALLATION
  1. Clean the gasket surfaces of the engine coolant pump body and the cylinder block.
  1. Install the new engine coolant pump gasket and pump assembly. Tighten the bolts to the specified torque. Tightening torque
Engine coolant pump bolt:
Head mark "7": 17 - 22 Nm(170 - 220 kg.cm, 12 - 16 ft. lbs.)
  1. Install the water pump fitting, the thermostat case and the water outlet fitting.
  2. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  3. Install the drive belt, coolant pump pulley and then adjust the auto tensioner.
  4. Refill the coolant.
  5. Run the engine and check for leaks.
Courtesy All Data LLC
© 2015 ALLDATA LLC. All rights reserved. Terms and Condit
Washer wont spin
The safety latch could be worn or stuck, the lid not closing tight enough to disenage the safety lever
How to replace waterpump
step 1. drain cooling system.
step 2. remove battery and battery tray.
step 3. remove drive belt.
step 4. remove water pump bolts ( 318 ).
step 5. remove water pump ( 300 ) and water pump gasket ( 314 ).discard gasket.
step 6. inspect and clean gasket mating serface.
step 7. install new water pump and gasket and tighten bolts to 89 in. lbs.
step 8. install drive belt.
step 9. install battery tray and battery.
step 10. fill cooling system.
Book time is 1.5 hours ( this one is what we call a gravy run ) good luck
2helpful
How to change a water pump
First drain the coolant if possible (you will find a drain **** on the bottom drivers side of rad). Loosen the water pump pulley bolts while serpentine belt still attached (10mm X 4). Remove the serpentine belt, and plastic diagram bracket just above the waterpump. Remove the (8mm bolts X 5) holding the water pump to front engine housing. Note the little arrow or triangle at the top of waterpump when removing, it will help you to install new water pump in same location. Scrape off most of the old gasket material, use fine sand paper to clean engine surface as best as possible. Install new gasket to water pump, and align the holes (it only goes on one way, and maybe upside down if they don't line up). Locate arrow and reinstall, torque 5 bolts to 89 in/lbs tight but not too tight. Reinstall pulley, serpentine belt and bracket. Tighten the pulley bolts, refill coolant (close drain ****). Just above the waterpump there is a coolant hose with a little 7mm screw for a bleeder. Open the bleeder (engine off). Continue to fill rad with coolant until it comes out bleeder. Close bleeder and test run. Recheck the coolant level later when cooled.
2answers
Replacing waterpump in1999 nissan pathfinder
Water Pump Removal & Installation To Remove:
  1. Allow the engine to cool and drain the coolant from the radiator and both engine block plugs.
  2. Remove the fan shroud and both radiator hoses.
  3. Remove the drive belts.
  4. Remove the water pump pulley.
  5. Remove the crankshaft pulley.
  6. Remove the timing belt covers.
  7. Remove the water pump.
Water pump removal/installation 7924vg20.gif
To Install:
  1. Install the water pump with new gasket.
  2. Install the timing belt covers.
  3. Install the crankshaft pulley.
  4. Install the water pump pulley.
  5. Install the drive belts and fan shroud.
  6. Install the radiator hoses.
  7. Install the coolant drain plugs.
  8. Refill the cooling system.
1helpful
How do i replace a water pump on a 1993 geo
1 disconnect battery ground cable
2 drain cooling system
3 on models with a/c, proceed as follows:
a discharge a/c system
b loosen upper and lower compressor bolts and remove compressor drive belt
c remove a/c line from top of radiator shroud
4 remove water pump drive belt
5 remove reservoir tank from radiator bracket
6 remove radiator shroud and fan/clutch from vehicle
7 remove waterpump pulley from waterpump
8 remove timing tensioner and timing belt
9 remove dipstick tube
10 remove alternator mounting bracket at water pump
11 remove water pump mounting bolts and water pump
12 reverse procedure to install, using new gasket and rubber seal
1helpful
2answers
How to install
4.9 disconnect negative battery cable,drain the coolant from radiatorremove coolant reservoir, loosen waterpump pulley bolts,a screwdriver can help keep the pulley from turning,remove drive belt,remove idle pulley,remove waterpump mounting bolts(they are different sizes,some are star shaped) do not pry on waterpump until all bolts are removed,clean gasket surface,use gagket sealant and install new water pump(start all bolts before you torque any down.)
1helpful
How to change waterpump on 2002 grand caravan 3.7L
drain engine coolant.disconnect negative battery cable.make to turn radio off so you wont lose your code.remove drive belt.remove right inner splash shield.water pump pulley then remove water pump.when putting on new water pump torque it .105 inch pounds.that about 7 to 8 ft lbs. water pump pulleybolts torque is 22 ft lbs.
2answers
Pully wont spin after waterpump replacement
pull the water pump back off and see if something got wedged in there. your son might have dropped something in there before he put it on.
11helpful
1997 dodge caravan waterpump replacement
OK, disconnect neg battery cable, drain cooling system, remove splash shield under right front fender for easy access to water pump bolts, loosen clamps and disconnect hoses from pump, remove drive belt, remove water pump pulley bolts, remove pulley (tip: loosen bolts on pulley before removing belt), remove water pump bolts (5) , separate from the front cover, clean the bolt threads and the threaded holes in the front cover to remove any corrosion and sealant, remove and discard o ring and clean mating surfaces, careful not to gouge or scratch mating surfaces, install new o ring into the groove, install the pump to the front cover and tighten to 105 INCH pounds, pulley bolts are 21 FOOT pounds.Good Luck! countrycurt0
Top Washing Machines Experts
john h
