Question about Roper RS22AQXKQ Side by Side Refrigerator
My roper refridgerator model # RS22AQXM000 does not get water up to the ice maker
We get drinking water but no water is getting to the ice maker
6ya staff
SOURCE:
Anonymous
SOURCE: roper ice maker
My ice maker was making ice just two days ago after being off for a while. I am a new tenant. I made one basket full of ice, which I dumped to make sure the system and water was flushed thoroughly. Now the ice is just stuck there, you can see the cubes but they aren't going anyway. I try to gently force them out, but no way, they aren't budging! So, how do I eliminate this problem?
Posted on Oct 06, 2008
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Posted on Apr 27, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: On a Roper ice maker, ice is not making but
In the back of the ice maker on top
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: my roper side by side ice maker does not work
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
See if the ice maker starts working when it dumps the ice.
Posted on Sep 28, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: no water going into ice maker on our roper side by side refrig
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Jan 05, 2010
Testimonial: "The solution gave something to try. Thanks"
The ice maker on my Kitchenaid KBF320EVMS4 french door refrigerator stopped working. The drinking water works fine and I can hear the noise when the ice maker fills with water but no water comes in.
you can pop the cover off of the ice maker,on the module you'll see some letters,if you get a jumper wire and stick it into the T and H the ice maker should start to spin,if it doesn't the ice maker is bad,then remove the wire and stick it into the V and L,water should start to fill the ice maker,if it doesn't most likely you have a bad water valve,just get a piece of wire,strip off both ends to make a jumper wire.one more thing,check the fill cup and the fill line to see if there's any ice in there,if the water valve is bad water can drip through and freeze in the cup or fill line stopping the water from entering the ice maker,if there is melt it out with a hair dryer,also if you have to get in there with a hair dryer be careful with the heat on any plastic parts,you can damage it and don't heat the fuse on the ice maker wires,it's a black fuse built into the harness you can damage it if it gets to hot.you can go here to see your parts
https://www.searspartsdirect.com/model-number/KBFS20EVMS4/0593/0161000.html?searchType=modelSearch&q=KBF320EVMS4&searchTerm=KBF320EVMS4
Nov 22, 2017 | KitchenAid Refrigerators
Why am I getting water but its not making ice?
this model has the double valve. one for drinking water and second to fill ice maker to freeze
and produce ice. Possible one coil for ice maker is not operating.
Check also supply tube to ice maker It is possible frozen and plugged.
Jun 23, 2014 | GE GSL22JFPBS Side by Side Refrigerator
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
HAVE WATER FLOW FOR DRINKING/BUT NO ICE MAKING GOING ON
is not the filter because you are getting water from the 1 icemaker or the water valve
Apr 07, 2009 | Refrigerators
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
