A common problem is the battery tab on the circuit board. We repair this by reheating the solder joint on the circuit board where the battery tab is attached.
make sure remote and dvd select the same setting DVD1 on dvd recorder, so DVD1 on the remote, ther is some writing in the manual how to change the remote from dvd 1 to 2 and 3
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
If changing the batteries did not resolve your issue with your remote, we may need to replace the remote. You might check to see if all batteries have the positive side facing down on the remote. If so, then call 1-800-333-3474, speak with Tech support. I hope this helps.
the best way to check the remote is to point the remote at a digital camera look in the viewfinder or the display and press the remote, buttons and if the remote is good you will see a small blue light at the very end of the remote!!! techman
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
