SOURCE: washing machine
this means the machine has tried to empty for 10 minutes check the filter and unblock it or else the drain hose is kinked or crushed, worse case scenerio is that you need a new water pump
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
