When power is switch on, the two green LED lights up but the screen remain blank .. after a few seconds, two green LED switch off and the red LED diagnostic blinks 3 times... then 4 times ... then continue blinking 4 times.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Thanks Local wonder.. but I would like to correct ... model number is SONY KV29SF1. and this is the problem...." " " " " --> When power is switch on, the two green LED lights up but the screen remain blank .. after a few seconds, two green LED switch off and the red LED diagnostic lights up for 2 secs... then blinks 4 times .and continue blinking 4 times " . However, There are times that the TV will normally operate after switching on.. Suspect problem with Horizontal ckt - unable to generate horizontal sweep current to operate the CRT which is being sense by the microprocessor protective circuitry.? This is a guess... as I dont have ckt diagram .Please advise..
I studied Radio TV servicing but practice Control system engineering.. So I still understand quite well TV circuitry operation and can repair down to component leve -- given the correct information. l. I just need familiarity with the operation / function of the IC used in this KV29SF1 , service manual and ckt diagram will be very helpful. There is no Sony service center near our place so I have to fix the TV ..Will appreciate if anybody can e-mail me a copy of Schematic Diagram..
LED blink and no power and i need circuit diagram. my email address is [email protected]
