My rc-1158 remote is not working, is there any other remote can be used/programed for controlling the home theater
SOURCE: Remote code for Sony Home Theater
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
SOURCE: programming
Here is the sony support site. i tracked down the manual section on the site, this is it
NOTE you must enter your TV Model to obtain the programming code
http://esupport.sony.com/CA/perl/model-remote.pl?mdl=RMTV501
SOURCE: can't get universal remote to control home theater system
all your codes for that remote can be had at
http://onlinehelp.verizon.net/consumer/bin/pdf/philipsrc144remotecontroluserguide.pdf
This works for ALL Sony Home Theater Systems
Remote Code: 21232 (a Sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Function = 44750
Mute = 33743
