Question about Mtd 22" Yard Machine Push Mower
Mower starts up great and then dies
I press the red button on the mower and pull the Recoil starter and it starts up great and then dies. My mower is a Yard Machines by MTD 21" Rear and Side discharge Mulching Mower Model Series 540..Help!
  • davepetrick May 24, 2009
    I just sharpened my blade to my MTD 21", changed oil and fresh gas. Starts great then dies within 1-2 seconds. Thoughts please?
    Problem Solver:
  • 8 Answers
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
  • Shirley A Davis Sep 14, 2014
    I did as you said. The bowl was clean and not
    Now, I'm trying to put it back together. Where does this little pin go?
    President:
  • 1,902 Answers
Your carb is either out of adjustment or it needs to be cleaned. The points or air holes are clogged. Spray some carb cleaner into the carb and let it sit it should solve your problem without having to take it apart
Posted on May 21, 2009
    Guru:
  • 479 Answers
This is likely to be a fuel starvation problem.
Fuel is fed from a reservoir called the float bowl. This works pretty much like a toilet cistern with a float to cut off flow once it fills. Once the bowl empties and doesn't refill due to a blockage, the engine will cut out.
Clamp off the fuel line or turn off the fuel tap. Remove the bowl, and check fuel flows freely. If it doesn't, there is a blockage in the fuel line which you need to trace.
Another scenario is that the main fuel jet is blocked or semi-blocked. This can cause the engine to run ok when idling (since the idle jet is ok and not much fuel is required), but cut out as you throttle up. This is because more air is sucked in, but not enough fuel is drawn from the main jet due to the blockage. So the mixture is too weak and the engine stalls. The jet can be cleaned with compressed air or ideally a carburetor cleaning aerosol.
Smaller engines such as Briggs & Stratton 3.5 HP types have a diaphragm type carburetor. The tank is mounted below the carbuetor and a flexible section of the diaphragm is pulsed by suction from the air intake manifold. This sucks up fuel from the tank. Check valves prevent fuel travelling backwards. These are just flaps of plastic forming part of the diaphragm. Over winter, the check valves can get gummed to the carburetor body, preventing proper operation.
See my comprehensive guide for getting stubborn lawn mower or other small engines to start. This also covers issues with the ignition system:
http://hubpages.com/hub/Why-Wont-That-Lawnmower-Start
Mower starts up great and then dies - mower-starts-up-great-dies-xoiwilb1fryjy1fsdwxqyhcm-1-0.jpeg
Posted on Mar 22, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mtd Master
  • 1,917 Answers
It is best to rebuild carb save money in the long term thats what us red neck do so should you
Posted on Aug 28, 2014
Anonymous
SOURCE:
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
Lawnmower cannot pull starter recoil
You can take the recoil unit out and replace it, you may also be able to recoil save that one if nothing has been broken
May 05, 2012 | Mtd Yard Machines 158cc Briggs and...
Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Aug 04, 2011 | Toro Power Lawn Mower
I just bought this lawn mover and recoil starter does not pull up?
You have to squeeze the safety lever on the handle to disengage the blade brake. This lever is meant to be squeezed while you operate the mower and will stop the mower instantly (well, pretty darn quick) if you release it while the mower is running.
Jul 06, 2011 | Mtd Yard Machines 158cc Briggs and...
I start twice (when I pull starter rope) then the rope won't go back can I know what happen
Your starter/recoil unit has malfunctioned. Disassembly/inspection down to the point where you can get the recoil off will be required. Remove the engine cover screws. The recoil unit may be part of the cover or may be under it. You will easily be able to access it. Replacement parts for your mower are readily available.
Apr 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Starter rope broken on victa mower. how do i rewind. Itwill not recoil once pulled out
It sounds like the recoil spring is broken. Take off the recoil unit and remove the pull plate replace the spring if it requires itl davidson lawn mower tech
Feb 08, 2011 | Garden
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Mtd 22" Yard Machine Push Mower Logo
7,361 people viewed this question
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
