mid Archos M729B Android Tablet Logo
Won't charge, won't turn on
One day it just wouldn't charge, Nothing happened to it, just wont turn on anymore
Nextbook 11.6
It sounds like maybe the battery died.
2answers
My Kindle won't turn on.
sounds like you did everything right
could call amazon see if they can help
or do a factory reset to eliminate software problems you will lose all your data
then there is hardware problems dead battery that won't recharge bad cable connection inside kindle
Reset Kindle Fire When it Won Turn on or Charge
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
21helpful
3answers
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
2helpful
I have been trying to turn on my galaxy tab but it just wont turn on. I have tried charging it for a full day but still nothing. i dont even know if it is charging.
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
Top mid Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a mid Tablet and eReader Expert? Answer questions, earn points and help others
