SOURCE: Cannot access Facebook's log-in page
Although I would still like to be able to access Facebook using Internet Explorer (and I still am not able to do so), I was able to work around the problem by installing the Firefox internet browser. Using it, I was able to access Facebook without a problem.
SOURCE: not able to open facebook home page
it is just a matter of connectivity....
just try after some time..
with seperate explorar
SOURCE: error page in facebook page
Try cleaning your temporary internet files, and your cache files. Depending on your IE version try updated to IE8. If you have a firewall such as zonealarm it might of switch to protected mode. The Program Switch will switch every 21 days.
SOURCE: Pge Load Error: Facebook home page won't load. I
Normally page load error represents, there is busy at serve side or otherwise low web access, but you have fine access, so there is a problem in server side, but you are accessing in iphone, so there is a problem in laptop, that is as like Iphone, there is lack of in-built functions in laptop to retrieve FB. dont worry about it right now!
if you want you can access FB which is integrated with IM such as digsby / Gabtastik / adium! have fine!
SOURCE: my facebook games wont load or they go half way.
please update your java files, go to my computer > control panel open java control panel, and select update. also games run better in ir due to the virtual machine environment. jre the java files call several hundred files to load your web games. this has major issues on speed, also note a virus scanner may be running in background,.this will kill bad files or slow loading files possibly.
