Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Fix #1: Remove the batteries from
(preferably rechargeable NiMH 2500mah or better) and turn the camera
on. If that didn't work, try pressing and holding the Function or OK
button while turning the camera on. Fix #2:
reset in some cameras. Error E30 (for older Canon's) means that you
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Try these: 1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error" 2) Recharge or fit new batteries. Use 2700 power if you can get them. 3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy! 4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism. I have used my S1000fd lots now, and the initial "zoom error" problems have stopped. It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Need Help
