Need source for gear case grease
The gasket your
looking for is part# 487224-00
SEAL which lists for $3.65. The gearcase should use LUBCON GLK 249 grease spread evenly
across the gears. Be careful with the amount you apply, too little grease will
not properly lubricate and too much will create additional friction cause the
to motor to work harder, thus reducing its effectiveness and longevity. ONLY
THIS GREASE SHOULD BE USED ON THE INTERNAL COMPONETS OF THIS TOOL. Note that
the bit grease is different than the gearcase grease and SHOULD NOT be used on
any internal components.
5g on connecting rod and piston - inside and out
39g in gearcase evenly coating all parts
39g in crankcase
