Have a new Blu-Ray player with but cant find a code suitable for my older AWA plasma tv. All codes in book are two digits only. Also, when playing blu-ray or any external drive movie, my screen goes blank. May be the frequency or format its playing in but I dont know how to change it to work, and Samsung cant figure it out. I know it all works with a newer LCD tv (Sanyo).
Http://schematicscom.blogspot.com/
http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Please visit these sites to get some details. Search the sites by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: Remote Control codes to control other brand devices
i have sony receiver codes 31759, 30158, 31758,
or 4 digit codes 0158 and 1758
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck [email protected]
SOURCE: Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
