Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water release(you can manually set the spinning and water release), In any other mode the machine makes a strange sound from the moment the start knob is pressed and shuts down for 15 to 20 minutes until the internal machine breaker resets.
SOURCE: Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
