Door latch assembly has this green plastic tube, wire, something like that that comes out of the switch but I have know idea where it goes can you help me? had to remove lid to fix front rubber seal and did not see where it got loose from. Any help would be great. It's the piece that inter acts with the door locked light
The plastic cord is for opening the door if the door latch fails. It should connect to the door latch mechanism and the other end should be routed to the soap dispenser corner. There should be two holes for the cord to go into and out again. The idea is to remove the soap dispenser lid / bezel to get access to the pull cord if needed.
Hear the new Neptune bearing song at http://www.neptunehelp.com.
