Thats a hard drive error. Initialize SP5-832-008 or replace the HDD! Most machines use a simple IDE HDD. Just open the machine at the back, youll see the HDD
Check exposer lamp to see if it comes on first. try printing counter report if same problem. Then could be drum unit or not getting a charge to roller on drum. then board could be bad.
Check to so if red light on next to print button.if so push it to see what screen is saying. If not then it could be a bad print file. Will need to clear printer que out on all computers and restart them and then turn copier off and back then try something that printed before
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
With out seeing copy here is my thought either bad drum if it is streaks down copy or laser unit for yellow is out of alignment . In user tools there is a maintance tab go into it and do color alignment if it fails then could be transfer unit or laser unit for yellow will need to have a copier tech come out to fix it.
