Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
The maximum number of shots possible is 24 or 36 depending on the film length, although sometimes you can squeeze an extra one out of a film. If the film loaded correctly you will get a frame counter in the LCD. If the film did not load correctly, then you have not taken any photos as the film is still in the canister and unexposed.
Take the camera to a totally dark room (and I do mean absolutely pitch black) and open the camera. if you can feel the film canister and just the short leader then it didn't load and you can turn on the lights and try loading again. if there is just the canister and no film sticking out, then the film has rewound and you can turn the lights on and send the film for developing to see if the camera worked. If you feel film going from the canister right across to the take-up spool, then your film is still being used and you should close the back of the camera before turning on the lights again. The latter does not necessarily mean that your camera is OK though as it should be showing frame numbers, but it may be usable still. If after a few more shots the camera is still behaving just the same then it's got a fault.
A faulty t70 is really not worth repairing. It's complex, spares are mostly unavailable, and they are almost worthless even in perfect condition. Any of the earlier non-t-series Canon FD-mount bodies are far better and a lot more fixable. They are also usually near worthless and can be picked up free or very cheaply, but as they have less to go wrong and were designed with repairs in mind then many common faults can be fixed.
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
1 You have to push the button to take the picture
2 Some of the cameras are auto loading. In that case once you take the picture it will move the film automatically.
3 If it is not auto loading then you have to move the lever to load film for the next shot
Battery contacts corroded? If so add a few drops of rubbing alcohol on the solder joints and the contacts. Let dry over night and try again with fresh batteries
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Hey buddy5000, The process to load film into your camera is as follows 1. Turn the camera on and make sure the frame counter reads 0 if it doesn't there is probably film in the camera. 2. Press the film door release button and slide the release downward. 3. Place the new film cartridge in the film cartridge chamber and pull out the film leader until it reaches the red dot on the bottom right side of the film chamber. Make sure the holes on the lower edge of the film engage the teeth on the sprocket. 4. Now close the back door and the film should load automatically and# 1 should appear in the frame counter, and if it does not then the film is not loaded properly. I hope this helps! Sincerely, Allan Go Ahead. Use Us.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
I'm assuming you're not able to shoot pics.
Its my best guess that the film just isn't getting loaded properly.
Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool.
I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
