The problem I have with Brother MFC-5840cn photocopier, it does not want to work it displays a message that says: see troubleshooting and routine maintenance chapter in user's guide so I would like to know what I have to do to solve the problem. problem.
https://translate.google.com
http://support.brother.com/g/b/faqtop.aspx?c=au&lang=en&prod=mfc5840cn_all
https://translate.google.com/translate?sl=en&tl=fr&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fsupport.brother.com%2Fg%2Fb%2Ffaqtop.aspx%3Fc%3Dau%26lang%3Den%26prod%3Dmfc5840cn_all&edit-text=
http://support.brother.com/g/b/faqtop.as...
https://translate.google.com/translate?s...
https://www.manualslib.com/manual/21757/...
SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
SOURCE: BROTHER MFC 5840cn MACHINE ERROR 4F
Downloaded service & repair manual for brother mfc 5840CW- my unit. Will follow repair directions to check the memory then replace required parts. Will be cheaper and faster than finding a repair shop and paying as much as the macine to fix it! Rip off prices for repairs today on units so they can get you to leave them and buy a new one. Then they fix the unit and sell it "refurbished"- not mine!
Your information on clearing memory, the ink cleaning codes and taping the cartridge from over cleaning was good. Thanks for the help!
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Open the top cover and hold the interlock switch on the top right hand corner. Power up and wait for the carriage to come to the center. Shine a flashlight all the way to the right and left and pull out the crumpled paper. You should be able to print again..
